Draytek or Netgear?
19 Mar 2007
I need two routers, one is in my room, and one is in another room, using different internet connections :)
Upgrading from a BT Home Hub...
http://www.draytek.co.uk/products/router_compare.shtml
Draytek 2800V, is this a good router? I had the previous version, the 2600, was great! Anyone have any experiences?
Another option:
http://www.overclockers.co.uk/showproduct.php?prodid=NW-086-NG&groupid=46&catid=116&subcat=143
I already have one of these in another location, apart from not having a modem with it :@...
This netgear has a modem with it :)
So what do you guys recommend?
Thanks.
I'm using a Netgear DG834N on my Be* connection (ADSL2) and it hasn't put a foot wrong! I get far better connection stability using this over Be's own router and far better sync speeds, the wireless is also top notch!
Well I'll probably get a netgear as their admin menus are so much sophisticated and easier to use, well... Netgear for me :D
Thanks for the reply btw.
Well I have a Linkskys WRT54G and I don't like it, the admin menu is really crap, and you have to have a modem...
I'm more into all in one type things, BUT, Cisco now owns Linksys, so eh....
I really need some decent wireless routers 'cos the house is pretty large, and I can just buy some 802.11n cards for the laptops and PC's.
Got any Linksys recommendations?
Cheers,
tem07.
am using the WRT300N at the moment, nice bit of kit
I also had a WRT54G and i quite like it also. You can run custom firmware on them if its just the UI that bothers you
Another vote for Netgear here also, although I am using a cable version, the Admin control panel options are excellent. I have it for hardwire through out my house, but I patched my neighbours comp to mine via the wireless. Again the router hasnt put a foot wrong. Plus my neighbour is more than happy with the wireless option, he games and browses a lot.
Although I have been toying with the idea of using the eletrical wire supply for networking, it just seem to make more sense of using existing wiring and removing m cat5 cabling, even though I made a decent enough job of hiding it. Leccy networking would suit my needs as much as the cat5. Plus make all me rooms accesable. From what I seen, guys using it have no complaints using it here.
Hope that helps a little.
Thanks all, it's probably 2 Netgears for the win! :D
Thanks for the comments on the routers etc.
Have any of you got any 802.11n cards? Are they good quality? Get good reception?
Thanks once again :)
Orange Peel said:
Me too. I've used D-Link, Netgear and a few generic routers over the years and my 2600 Vigor is faultless :) Best overall package IMHO.
Still using my Draytek 2600VG and it's great :D
Will be replacing it shortly though (With a Cisco 1841 once I'm happy with the config) ;)
Cisco have owned Linksys for getting on for four years, that's like pointing out walkers crisps now come in foil bags :p Draytek imho. The WRT54G is actually one hell of a router once you flash it to a 3rd party firmware, but then again if you are only after it looking nice I think you missed the point about Function > Eye Candy.
ditto, solid piece of kit that does everything i could want and more. draytek all the way
Nah man, I'm looking for a decent router, I don't really care about what it looks like [reasonable though].
'Cos the Draytek looks dull still :P
Meh, I'm probably going to get the Draytek :D
Is it a doddle to setup? Anyone on BT broadband here, do you need the password and login to use the internet?
Actually, I was thinking, what about this router?Linksys WRT350N
Cheers,
tem07.
Get a draytek, my virgor 2900 rocks. never ever going back to netgear or the likes again.
Function over style always.
Netgear while a good router cant compair to a draytek, though if you have a DSL max based line make sure you update the firware with the 2800's as there is a known bug with the older firmwares (mainly because the router was out before bt rolled out DSL max).
lol that always works get both (its always good to have a spare because if you ever have a fault with your broadband you can rule out everything on your side easily before you contact your isp).
