draytek Vigor 2762 Vlan Help
16 Jan 2006
Internet
Hi and thanks for reading
I not sure why as its worked on another routers before but i cant seem to get this draytek working with a vlan at home
i want to have my home network on lan 1 192.168.1.1 and my office at home on 10.0.0.1
i have set up the vlan like this
I plug the cable for my office in to p4 port on the router ( the cable then goes to a 24 port switch in the office) but it just doesnt work, dhcp not working and if i set static addresses it doesnt work - even tried just a laptop direct in to port 4 and nothing - the strange thing is wifi on ssid2 for 10.0.0.1 works i can connect i get dhcp and can access the router on 10.0.0.1 fine but nothing else.
Any idea's what am doing wrong?
Thanks
Dave
forgot to add as i have just found out. None of the lan ports work at all only wifi with the above configuration.
I could be reading it wrong, but looking at the second image I think you're tagging VLAN20 on port 4 and you should have it untagged there. So for it to work the client that you're connecting to that port would need to be doing the untagging.
Untick both the checkboxes in the VLAN tag column.
Edit - You're untagging VLAN 10 on the other LAN ports so that'd explain why they're not working as expected.
With your current config, you would need to configure devices for VLAN tagging. As @the-evaluator says, disable the VLAN tagging within the 'VLAN configuration' settings and it should work as expected, ie - Ports 1-3 uses LAN1, port 4 uses LAN2.
Turn off VLAN tagging if you just want a port to be on a different network.
I've no idea why DrayTek haven't employed a team who can design a UI at any point in the past 20 years but that's what it is.
