Hi all,
I've recently acquired a Draytek Vigor 2830n-Plus and just this weekend have upgraded my Broadband from Virgin Media to 200Mbps.
Last night, I connected my Laptop to the Super Hub 2ac, reset to factory defaults, took two speedtests and I got 212Mbps/13Mbps (down/up), then switched it to Modem Mode.
I used the Draytek Firmware 3.6.8.4db which is the latest, and used the .rst variant to set it all to factory defaults then connected the Super Hub to it.
I can only get around 110Mbps/12.5Mbps from the Draytek Vigor 2830n-Plus.
http://www.speedtest.net/my-result/5203806074
QoS is disabled on all WAN's, DoS is also disabled and WAN2 is set to Auto negotiation. Load balance is ticked, should this have any bearing on speed?
Any advice appreciated, thanks!
