So I am in the process of upgrading to a fibre connection for VOIP at work, and whilst I am being provided with a managed Cisco router for QoS, the provider has strongly recommended using this as in bridge mode and keeping my existing router (a TP Link ADSL modem/router) so I can easily maintain the DHCP server for the network as well as firewall settings.
However as I have a second router attached via WAN to provide a second separate network for PCI DSS purposes (this was advice provide by the card machine company), the current router will not have enough LAN/WAN sockets for the required connections - also with impending VOIP traffic I think an upgrade is for the best.
Looking at the Draytek Vigor 2926, it has 2 WAN ports. However in the literature it appears these are designed for multiple incoming internet connections (as load balancing or backup) rather than connection of a secondary network to access the internet via the Draytek. Is it possible to connect the Cisco modem to WAN1, the second router to WAN2 and therefore internet will be accessible from both networks or will the Draytek not allow this?
Thanks for the help with this - it’s not clear to me in any of the manuals or online information!
Edit - if there is a more suitable router (WiFi necessary) please feel to recommend.
