Draytek Vigor 3300 can't access interface
28 Sep 2004
London
I've just taken over the fairly basic network here at work which relies on a Draytek Vigor 3300 router (no VOIP cards).
I can telnet in to it with no problems, but really I want to use the web interface. Just typing its IP into a web browser simply times out. I've tried this on multiple computers on the network with no avail.
There's nothing in the telnet commands that mentions enabling a web interface and I spent half an hour on the phone to Draytek's support line yesterday who couldn't figure it out either. I'd rather not reset it (as they suggested) as routing is set up for ftp/fileservers which clients are constantly using.
Anyone here have any experience with this router? Is there something I'm missing?
Cheers
Someone has maybe changed the port that the web interface is running on, they may also have specified that it can only be managed from a certain IP address.
I'm pretty sure it's possible to check and configure both of these from the Telnet / Console interface.
I've changed the port to 8080, just to make sure it wasn't that, and it doesn't work. Not sure about ipfiltering, but I'll look in to it.
Thanks!
