Draytek VLAN/Subnet question
Ish
Ish
11 Jan 2006
West Midlands
Hi
I need some help with this please.
Lan 1 is set to give out an IP 192.168.1.xxx
Lan 2 is set to give out an IP 192.168.2.xxx
Lan 3 is set to give out an IP 192.168.3.xxx
Looking at the setup below which Lan will anything connected in to port 5 get an IP from?
Tagging is not used.
The reason both are ticked is because the devices on Port 5 need to see the devices on Port 1-3 and vice versa.
I think you're in the wrong place for that.
Look under LAN->General Setup and then Inter-LAN routing.
Anything plugged into port 5 would need to be VLAN aware and tagging would need to be enabled. Routing between LANs is done in the router interface and not the switch.
