Draytek Wireless ADSL Router - WEP/WPA Problems
19 Jan 2003
Bristol, UK
Hello,
A friend asked me to check out his new router, a Draytek ADSL model. Unsure of the exact number but it has support for USB printers and is VOIP enabled.
The problem I am having is that I am unable to get WEP or preferably WPA to work.
The computer in question is a new Toshiba laptop and the manual says it's wireless adaptor supports both 128bit WEP and WPA. However, when enabling these on the router the laptop will fail to connect.
I have set up so many simple wireless networks, using pretty much every <£100 router on the market. Never have touched Draytek products though (I do read that they are pretty much the best though).
I have came across the problem probably twice before with other products and have never found a resolution.
Any advice much appreciated,
Chris :D
