- 1 Jun 2020
Hi All,
I have a budget for a PC between 4.5k-5.5k all i will use it for is gaming FPS / MMORPG.
I will most likley aim for a high end 1440p Monitor instead of a 4k one (not included in budget) but would like recommendations for this aswell!
Do you think i should get a liquid looped PC like the expensive pre built ones on overclockers website? the toxic etc
Looking for all your opinions or custom recommendations thank you.
Jack R
Jack R
