I ve got the pal dreamcast and i ve bought the vga box recently,
The problem is that it does not work with my AOC 19' crt monitor.
It seems that the monitor is receiving signal because when i try to turn the minitor on it does not display the "no signal" message.Also if i unplug and plug the display cable from the console the monitor turns on,(you know ,it make that tic tac sound) and then goes to "sleep" mode again.
If any1 has any advice i would be greatfull.
p.s. The vga box has a tv/vga switch and i ve tried both modes.Display wont depic anything but sound seems to be outputed fine
p.s.2 I only use original discs which have the vga compatible icon on the back of it's cases.
Thank s for your time
