Hey all,
just wondering if you could help me out as i'm stuck!
for one of my third year modules i need to produce a a geography subject leader file (used in schools to co-ordinate a subject) usually these are paper based bu i've decided to do mine as a website to break the mould.
i've constructed the site on dreamweaver 8 and hosted it on my hard drive with the aim to burn it to disc and hand it in electronically. i would host it but i can't get marked online as i could change it after its been moderated or something.
i stuck all the files on my pen drive and all the links wok on my computer, however when i burn it disc (everything loads up fine on my computer) and use it on the dining room computer (winxp pc) it does not load up my fancy background etc. but just has everything i have inputed in black and white the headers and stuff don't load.
am i missing a file?
i modiifed a css template i found on the net called brightside do i need to include the brightside images folder for it work?
my deadline is not till May 20th so i'm in no rush but your comments and suggestions will be gratefully received!
thanks in advance,
Josh
thanks in advance,
Josh
