Dreamweaver Behaviours.
8 Oct 2005
Midlands, UK
Hi all,
quick question: I have a connection to an oracle database setup in dreamweaver. I can creat recordsets, populate combo boxes, add/delete data etc. However, i seem to be stuck on the most simple bit - displaying all data from a table :( I have tried creating repeat regions, but it always displays the 1st record only. Any ideas?
Thanks
tbh i think you might be in the wrong forum as the troulbe is pretty much everyone here, and espcially the regulars, will be hardcore notepad++ programmers which means they don't use dreamweaver. every now and again you get someone who uses dreamweaver but afaik that amount is very small. have you either tried googling the problem or googling for a better forum which is designed to help with your type of problem?
