Dreamweaver CS6 stops working after update
3 Dec 2002
Groovin' @ the disco
Hi
I've just installed the master collection of CS6, and after the update. Dreamweaver stops working. Its comes up, with supported on this mac, which normally refers to the version of the OS. We are running 10.6 (SL) at the moment, and don't really want to upgrade at the moment due to needs to other software.
Anyone know of another solution apart from upgrading Dreamweaver?
Thanks
Hi
Just a note to say I've sorted this issue out. If I ran dreamweaver (same issue with encore) then run the update it works fine.
I would suggest to anyone that before they run the update, delete the plist files, re-run the program to recreate a default plist, then run the update. As the issue does seem to be common on many of the different programs within CS5.5 and CS6 and people have been uninstalling and reinstall the program.
