Hi
I am having issues with my Dreamweaver on my computer. Every time I open the application, Dreamweaver, I get this error popup that says:
The following JavaScript error accurred:
At line 56 of file "C:\Program Files\Macromedia\Dreamweaver 8\Configuration\Shared\Common\Scripts\dwscriptsExtData.js"
ReferenceError: dwscripts is not defined
I click ok and then i get this message
While executing onLoad in _onOpen.htm, the following Javascript error(s) occured:
In file _onOpen:
ReferenceError: onOpen is not defined
I get the onOpen message a few times when Dreamweaver is loading up.
I have installed it already and no luck.
The when i click the OK button, this same pop up appears again.... Does anyone know what this means and how I can fix the problem? In cant copy or paste in dreamweaver too, it also occurs when I save a file was well.
Please, help.
In file _onOpen:
Please, help.
