Dreamweaver issue
19 Dec 2005
Perth, Western Australia
Hi,
I have a site i built in dreamweaver but when i minimize ie the footer and centre part shrink and squash into the window.
How can i force the css to keep all the imagse etc the same size even when ie is minimized.
Thanks
Hi mate, thanks for the reply,
which ones do i need to change if i change them all the page goes nuts.
This is the css i am using
@charset "utf-8";
body {
font: 100% Verdana, Arial, Helvetica, sans-serif;
background: #666666;
margin: 0; /* it's good practice to zero the margin and padding of the body element to account for differing browser defaults */
padding: 0;
text-align: center; /* this centers the container in IE 5* browsers. The text is then set to the left aligned default in the #container selector */
color: #000000;
.twoColLiqLtHdr #container {
width: 80%; /* this will create a container 80px of the browser width */
background: #FFFFFF;
margin: 0 auto; /* the auto margins (in conjunction with a width) center the page */
border: 1px solid #000000;
text-align: left; /* this overrides the text-align: center on the body element. */
background-color: #FFFFFF;
.twoColLiqLtHdr #header {
padding: 0 10px; /* this padding matches the left alignment of the elements in the divs that appear beneath it. If an image is used in the #header instead of text, you may want to remove the padding. */
.twoColLiqLtHdr #header h1 {
margin: 0; /* zeroing the margin of the last element in the #header div will avoid margin collapse - an unexplainable space between divs. If the div has a border around it, this is not necessary as that also avoids the margin collapse */
padding: 10px 0; /* using padding instead of margin will allow you to keep the element away from the edges of the div */
.twoColLiqLtHdr #sidebar1 {
float: left;
width: auto; /* since this element is floated, a width must be given */
background: #0066FF; /* the background color will be displayed for the length of the content in the column, but no further */
padding: 15px 0; /* top and bottom padding create visual space within this div */
.twoColLiqLtHdr #sidebar1 h3, .twoColLiqLtHdr #sidebar1 p {
margin-left: 10px; /* the left and right margin should be given to every element that will be placed in the side columns */
margin-right: 10px;
background-color: #0066FF;
.twoColLiqLtHdr #mainContent {
margin: 0 20px 0 26px; /* the right margin can be given in percentages or pixels. It creates the space down the right side of the page. */
.twoColLiqLtHdr #footer {
padding: 0 10px; /* this padding matches the left alignment of the elements in the divs that appear above it. */
background:#0066FF;
.twoColLiqLtHdr #footer p {
margin: 0; /* zeroing the margins of the first element in the footer will avoid the possibility of margin collapse - a space between divs */
padding: 10px 0; /* padding on this element will create space, just as the the margin would have, without the margin collapse issue */
/* Miscellaneous classes for reuse */
.fltrt { /* this class can be used to float an element right in your page. The floated element must precede the element it should be next to on the page. */
float: right;
margin-left: 8px;
.fltlft { /* this class can be used to float an element left in your page */
float: left;
margin-right: 8px;
.clearfloat { /* this class should be placed on a div or break element and should be the final element before the close of a container that should fully contain a float */
clear:both;
height:0;
font-size: 1px;
line-height: 0px;
You haven't shown any actual columns or anything but try messing with the only set width you have which is this.
Try changing that to however wide your layout actually is in px. (960px for example)
