I presume the .inc files are somehow dynamically included in a page on the server-side (SSI? PHP?). If so, then I don't believe it's possible unless you can get Dreamweaver to act as a webserver.
No loss though, the code output of the design-view in Dreamweaver is terrible - use the code-view instead .
I use .inc files for a couple of sites. If I need to view them in Dreamweaver I change them to .htm and then back to .inc when I am finished with them.
Get Apache, or your webserver of choice, running locally on your machine - that's the most common way to develop. Then all you need to do is make a change in DW, alt-tab over to your browser and refresh .
If you don't feel up to installing Apache and the rest manually, then look at a one-click package like XAMPP.
