I have a dremel clone (cheap and cheerful) and today while doing some work on my CM mod entry i used up all the cutting disks that came with it - they were pretty crap and broke easy.
So now comes the time to buy some (proper?) new ones, i've been looking on ebay and there are 200+ piece sets for around £20, would these be any good? I've also seen diamond disks and i'm sure i've read before that diamond disks are the best option.
So any advice on what to go for, my case is aluminium?
If you look about you can get cutting disks that last abit longer and do not break, the only thing is that the disks are abit thicker than the normal ones that snap all the time.
