Dremel for modding?
24 Apr 2009
Hello
can anyone recomend a dremel for modding? I have looked online and found quit a few so some advice on which are good would be useful.
I already have an assortment of tools at my disposal but dremels seem to be the popular option when modding cases.
I have a Cosmos pure, whish is renowned for its poor cable management.
so I will be aquiring some rubber grommets like seen in corsair cases to install to solve that problem, which will need a hole to go in.
I also am considering putting a CPU mount hole in the back of the motherboard tray as it is quite a chore to install my motherboard, CPU cooler and still be able to plug things in. what type of lining should I use for that hole as the chance of me getting a perfect finish is low.
I will be buying a FX8150 upon release, hoepfully soon and will have to remove my motherboard to fit it anyway so this would be the ideal time to implicate these mods.
this won't be for looks but mainly for convenience, I will create a build log when I get round to doing this.
Thanks in advance.
If I was you I'd ask this in the case section, they do a lot of case mods there and seen a few posts regardnig dremels and such in the past
