DRGB strip lighting
24 Jun 2003
So my new case ( Lian Li 011 Dynamics XL ) is arriving today for my 1st waterclocking adventure.
my MB supports RGB Fusion which i will be using to control the rgb fans , mb leds and digital led strips.
ive been looking and seen the Phanteks digital led strips ( 550mm and 1000mm )
I've also seen some unbranded DLED strips on the Bay which work out cheaper.
My question here is which one should i go for ?
Which one do you guys use ?
I'm a big fan of CableMod's RGB kit, with or wthout the controller as neccesary, as they offer strips that do both RGB and UV (at the same time, if you really want), and they're both adhesive and magnetic. Very well made, too!
Personally, I bought into the Aquacomputer ecosystem, so I use their RGBpx stuff. Not immediately compatible with standard ARGB headers, but they do little adapters for a couple Euros.
I've already binned enough cheap LED strips to not buy cheap again.
