I have a Nickel-Cadmium drill. It's heavy and loses power quick. I also have a wall-plugged drill that's heavy. I've been putting off buying a new one, but recent weather events require me to fix a few things. I need one that drills through tile, wood and possibly even brick with one hand.
I'd prefer a Lithium drill with a USB-C charging port. However, I'm price-sensitive, and have a One4All gift card from Christmas. I can use it at places like Argos and B&Q, and was wondering whether their entry-level 18v drills were worth getting. I looked for reviews on Youtube, but the landscape is cluttered.
Is the Black + Decker Cordless Hammer Drill with Battery - 18V from Argos a good buy? It's 25% off till March - £41.25 - making it only £1.25 more than Amazon. I also like being able to return it to a physical store if it gets busted. My One4All gift card would also drop it to £16.25.
How do the Guild, Mac Allister and Ryobl drills fare? Don't want to spend too much, but the £25 gift card gives some flexibility, assuming the product's not costed up compared to online prices.
It probably won't affect you, but make sure you're aware of the chuck size and any limitations that may have as most cheap drills have a 10mm chuck.
