Drill bit help please
23 Nov 2004
Hi there, looking to drill a 40mm hole for a push button flush on the toilet so my dad picked up a 40mm hole saw.
I notice we need something else so purchase http://www.diy.com/nav/fix/power-to...-Holesaw-Arbor-With-Drill-Bit-11-1mm-11407733 to hold the hole saw.
The arbor doesn't fit in the smaller sized head on our drill :rolleyes:
I can't see an adapter on the B&Q site so can anyone point me in the right direction please?
Do what I did, buy a cheap tile diamond blade from eBay, tile over then drill through the tile and the backing, tidy up and fit the push button.
Should cost <£10 each, I bought for every event, push button, rad pipes and shower head, all last a couple of holes before burning out and just making a mess but are a cheap solution without buying a whole set and holder.
It is a wired drill we're using but its a pretty old one as far as I can remember. Can't see that screwfix site for some reason, signal is crap in this hospital.
Its only a wooden panel we're drilling and it won't have tiles over it.
Next question...is it ok to trim a little off the inlet to the cistern? With the 90 degree elbow ifs sitting a little close to the side of the the unit for my liking and the inlet has room to spare.
You're drilling wood!
Then use a wood drill bit
http://www.amazon.co.uk/gp/aw/d/B0070ZA206/ref=aw_d_iv_diy?is=l
