- 31 May 2009
Bit of advice needed please.
Need to drill through a solid wall right above a door frame, some form of reinforced lintel is in place.
Normal 10mm masonary bit isn't doing the trick, very slow progress once through the plaster, not standard block being drilled into, door header.
What is the bit of choice for going through something reinforced?
- and if cabling is to go through, need to make a hole mayeb 15mm by 20mm, what sort of stopped spacers etc can one place over the cabling to tidy up the mess in the wall, or is it better to use filler and a spot of paint?
