drilling 4" hole through brick
  • Thread starter Thread starter dal
  • Start date Start date
dal
dal
10 Sep 2005
Lincolnshire
Hi all, I'm going to be fitting a online fan in the loft to extract from my bathroom, this will involve drilling through a brick wall. As this would mean drilling whilst up a ladder im thinking of drilling from inside the loft. Would doing this give me a clean exit hole on the outside or would it blow the brick like a normal drill would.
Thanks
drill pilot. get hole started from outside and get about half an inch into the brickwork. then drill from inside. if you pilot but drill the whole thing from inside then you will definitely blow the bricks out. just go slow with it and don't push too hard when you think you're close.
Cheers guys.
I take it I should drill at a slight upwards angle to avoid rain running in
Also would it matter if my pilot hole was a bit bigger than the guide drill on the core cutter
Yeah you don't want to drill too far in from the outside with a core cutter if it seizes it could knock you off like nearly happened to me.
You don't need to be drilling at an angle there will presumably be some sort of grill or cowl on the outside to stop water going in and if the hole is wonky it might not mount flat.
Just out of interest how do you go about drilling through a cavity wall, as to avoid blowing the bricks out inside the cavity?
You will need a 113mm core drill, trust me on this one :)
I have drilled upto 163mm in a brick wall (have drilled 5 of these so far!), it will take awhile, better to get a scaffolding tower or platform as when it snags, it may throw you off if you cannot brace it.
Also, get an SDS plus drill and adapter, you will really struggle otherwise.
DO NOT DO THIS WITH A CLUTCHLESS DRILL.
It will hurt you, especially up a ladder (i.e. you' might get thrown off). I did a 125mm hole to take a 120mm tube, and it didn't fit so had to make modifications, so buy a cutter a bit bigger than you think you'll need.
Even with a drill with a clutch it can take you by surprise when the core cutter snags (and it will, a lot), I wouldn't even consider doing a big hole with no clutch as a safeguard.
The alternative is to chain-drill through the wall if you don't have a clutchless drill. Of course, if your drill has a clutch - as you were. :)
Good point, completely forgot that one! My SDS doesn't, and had to brace it pretty hard for when it snags. I thought I had broke my hand at one point, was drilling the 163mm core out, snagged and the drill spun round and smacked my hand. No feeling for a few minutes, but got away with it!
You can hire the proper drills from pretty much any hire place!
Thanks
I did this recently from inside out using a coring bit with a guide bit.
Equipment
* safety goggles, mask (dust) and hearing protectors
* I had a vacuum cleaner going to help cut the dust down a little - not much dust to be honest but you'll need one to clean up the mess away..
* Drill must have a safety clutch - this means if the bit bites the drill will not whip out of your hands. You'll want two hand grips. I used a 240V 850W SDS set to rotary. The SDS arbor helps without slipping. I think you were all sick of hearing about my Bosch SDS :p but the clutch is a must - mine caught a couple of times.
Overkill for one hole.. but I've used it a lot: http://www.screwfix.com/p/bosch-gbh-2-28dv-2kg-sds-plus-drill-240v/65597 - it takes about 5 seconds to put a 10mm x 50mm hole in the wall for bolting in the garage :D As I said it's the clutch that's important, the weight because you need to hold it with two hands as it cores.
* I used a Ebaur coring bit with extension arbour and guide bit - basically the following - note the weight of it will be almost 2 Kg of drill bit..
http://www.screwfix.com/p/erbauer-diamond-core-drill-bit-107mm-x-150mm/28948
http://www.screwfix.com/p/diamond-core-kit-5pcs/83176
The arbor extension was enough to get through a block and brick wall easily.
Drilling:
1. select point - i drilled from my loft out, so a point was easy to locate and mark.
2. Drill a small dent to prevent things moving around
3. set up coring bit - adding the extension and guide bit, the drill should be setup for rotation not hammer with a normal coring bit.
4. Drill initial 1" careful to set the path in a downward fashion so that any water/condensation will flow to the outside of the house. Ie the inner hole is higher than the final butter whole. After the first inch remove the guide bit incase it falls down the air gap between bricks. The dent for the guide bit stops things skitting around.
5. continue coring the inner brick/block until it gives. Extract the bit - take out the block core and leave to cool a little and ensure you're happy with the size and angle before getting to the outer bricks.
6. Reinsert and slowly start into the brick itself. You'll not need the guide bit as the hole in block will act as a guide (if you adjust the positioning you may need the guide bit until the coring bit can keep itself true - only a centimetre required but you want to remove the guide bit asap).
7. Easy does it.. and then pop as you go through the wall. The outside hole for me was perfectly round.
Installation points:
1. When you install the tube through the wall you don't want water dripping down inside the air gap. For this reason you should measure up and then seal/glue the pipe. If it's a telescopic tube the outter tube should connect to the outside, the inner tube should connect from the inside of the house. This means any water flows and will not pool at the joint only to find its way through to the air gap brick work...
2. Outside - seal the tube and brick to prevent capilary action and put a vent on the outside to stop wasps/birds etc attempting to use it..
Using rotary rather than hammer means you'll get a clean cut without exploding the back of the brickwork as you drill through. Also by not having the guide bit in, it means you will not get a single point pressure causing a blow out.. the coring bit will simply grind it's way through leaving a smooth entry and exit.
Diamond core drill
You can drill from the inside out with no blowout on the outside (provided you don`t use excessive push on the last little bit)
Seconded as Nickk said :)
cheers guys. Would it be ok if the pilot hole that I drill all the way through the wall first is slightly bigger than the guide bit for the core cutter as mine is 10mm and I think the guide bit is a bit smaller.
Only need a small initial dent.. the guide bit will then make it's own way. You should remove the guide bit once the coring bit has is a 1cm or 2cm in so drilling through the entire wall for a pilot isn't required. Worse case scenario is that the guide bit comes loose and drops down between the two sets of bricks/blocks so removing it is the best option.
