Drilling into drive bay plastic
25 Oct 2002
Any do's and don'ts for drilling small holes into a drive bay cover please?
Want to get it right first time and don't really want to make a mess
m
m
Measure twice, cut once. Start with a small 1mm drill for a pilot hole, then use the bigger drill. This will ensude that the drill doesn't slip and wander all over the place. And maybe set the drill on a fairly slow speed or it might start to melt the plastic. Good luck. :)
Make sure you go slowly and let the drill bit do the work. Have seen people splitting plastic by rushing in the past.
i have the same problem but i want to drill into my lian li alluminuim drive bezels to fit some cathode switchs but what would be the best way, the way to have listed above or what ? please help me as well and i am not gatecrashing this mans thread. ?? :cool:
Yeah, same way pretty much. As w3bbo mentioned, you'll want to mask it off as well. If you take your time, it shouldn't be hard at all. I really enjoy working with aluminium. Its hard enough to keep shape, but soft enough to work with.
I did exactly the same thing on a pc7 for someone yesterday, if you take your time it`s easy, i`ve used this method for absolutely ages,in fact i fitted 2 cathode switches into a 3.5 bezel on that one i did yesterday.Mask off the Bezel,mark out the center of your proposed hole,drill a small pilot (i use 1mm bit).Take a 20mm flat Wood bit (Zip bit) use the pilot hole you drilled to center the point on the flat wood bit, set your Drill to slow,and take out the hole that way.A 19mm flat bit will do it,but you might need to use the Dremel to make the Hole slightly bigger to allow the locating lugs on the switch to pop through.This works for all the Akasa switches,and most of the others i`ve fitted too.Hope that helps :)
On metals and hard plastics a centre punch will reduce drill bits slipping and spoiling the surface, automatic ones are easiest to use and only a couple of quid.
Or improvise with a hammer & nail but pack out with wood to prevent buckling.
