Drive Bay Kits
So they're too big?I wanted to buy them because I bought some air filters for my 2 intake fans in the front but they won't fit.I mean they're to thick and because of that I can't fix the fan holders back in place.So yeah the main reason for these was the incorporated fan filters.I don't get it...why the heck does the Antec 300 come with built in air filters and the 900 not.
Height and width won't be a problem as they're set standards but the depth might cause you a bit of bother. It's not just the overall length of the parts but whether the screw holes line up with the holes in the Antec in such a way as the front of the cage is level with the front of the case.
