Drive bay pump and res
7 Dec 2007
Hey, I was thinking about buying the XPS Dual drive bay pump and reservoir to save a bit of space in my case and was just wondering what you guys thought of that model and drive bay ones in general.
my brother got one, it had an intermittant pump fault so if it fails its a pain in the arse to get back up and running quick, i guess if you give it a 24 soak test you'll be fine.
TBH I personally think they are fine, i've a few m8's who are using them, and I have been using the stand alone XSPC pump/res and they have all been fine and worked great.
For a basic loop you should have no problems using one, just stick to high flow blocks and rads.
