Just completed my first build and all working OK. Installed XP last night and it has put itself onto the G: drive. C, D, E and F are allocated to card reader (integrated with floppy) and optical drives.
Two questions really:
a) does this matter? my understanding is probably not, although some software may only install to a C: drive - is this likely to be a problem these days?
b) how could I change this if necessary? I can't use Windows to reallocate letters as it's installed itself on G: so assume it would mean a reinstallation. However I didn't see any option when starting things up (either in Windows or the BIOS) to adjust this. How do these get allocated - given that all my previous PCs have had the hard disk allocated as C: and optical drives after that? Motherboard is an ASUS M2N-E btw.
Thanks
Thanks
