Acronis True Image 10 will do this, it's compatible with Vista 32bit & Vista 64bit, there is also a free trial available for download. i've used it in the same way that you require with Vista 32bit and it worked a treat.Scottland said:Acronis Disk Director doesn't work. I just want to copy my boot partition onto a new hard drive, rather than re-install.
Does anyone know of an app that'll work?
Thanks
d.chatten said:Acronis True Image 10 will do this, it's compatible with Vista 32bit & Vista 64bit, there is also a free trial available for download. i've used it in the same way that you require with Vista 32bit and it worked a treat.
Hope this helps!
Yes it's an excellent app, you can also resize your partitions to be as small or as big as you need, as long as there is enough room on the new HDD for the data.Scottland said:Cheers, I assumed that also wouldn't work![]()
