I'm using a 300GB IDE drive in my ubuntu pc/ What software do you recommend for partitioning it (i want a data partition and a partition to store a working image) and which file format should i be using to format the partitions with?
Also what would be the best way of creating the image? I'm used to PQDI and Ghost and can run them from a bootcd if that would do the job unless there are more ingenious methods with linux!
JM
JM
