Drive Through ATM's
13 Dec 2006
On the forest moon Endor
They've got them in America so I suppose it's only a matter of time before they're introduced here allowing customers to withdraw cash without leaving their vehicles. To enable customers to use this new facility the following procedures have been drawn up.
MALE PROCEDURE
* 1 Drive up to the cash machine.
* 2 Put down your car window.
* 3 Insert card into machine and enter PIN.
* 4 Enter amount of cash required and withdraw.
* 5 Retrieve card, cash and receipt.
* 6 Put window up.
* 7 Drive off.
FEMALE PROCEDURE
* 1 Drive up to cash machine.
* 2 Reverse back the required amount to align car window to machine.
* 3 Set hand Brake, Put the window down.
* 4 Find handbag, remove all contents onto passenger seat to locate card.
* 5 Turn the radio down.
* 6 Attempt to insert card into machine.
* 7 Attempt to insert card into machine.
* 8 Open car door to allow easier access to machine due to its excessive distance from the car.
* 9 Insert card.
* 10 Re-insert card the right side up
* 11 Dig through handbag to find diary with your PIN written on the inside back page.
* 12 Enter PIN.
* 13 Press cancel and re-enter correct PIN.
* 14 Enter amount of cash required.
* 15 Check make up in rear view mirror.
* 16 Retrieve cash and receipt.
* 17 Empty handbag again to locate wallet and place cash inside.
* 18 Place receipt in back of checkbook.
* 19 Re-check make-up again.
* 20 Drive forwards 2 feet.
* 21 Reverse back to cash machine.
* 22 Retrieve card.
* 23 Re-empty hand bag, locate card holder, and place card into the slot provided.
* 24 Give appropriate one-fingered hand signal to irate male drivers queuing behind.
* 25 Restart stalled engine and pull off.
* 26 Drive for 2 to 3 miles.
* 27 Release hand Brake.
Drive through banking is probably the most convenient thing America has to offer! It truly is awesome :D I dread going to the bank when I'm in England!
Seriously?
It really is little wonder that Americans are regarded as fat wasters by the rest of civilised society.
A work colleague of mine just moved to our Houston office and said that Walmart have got golf cart-esque buggies to take shoppers to and from their cars to the entrance....40 or so paces away!
