Old Wino said:OK here at 2x antiliasing but when I just now pushed it to 8x it put me back to basics (640 x 480). Maybe you pushed your system settings beyond what the game thought it could handle.
I'm also running an 1800xt.
Try letting the menu set the recommended settings and then 'up' it gently from there till you find the limit.
Good luck![]()
my point is with an X1800XT you should be able to rum it on maximum settings, hell my old GTO2 gave me more than what i could set here...
willthepirate said:haha arent computers a bitch man,
anyways when u get it running pick up the expansion its sick
nope 8 x af, ati cards don't support 8 x aa.MeatLoaf said:I thought if you activated High Quality mode then 8x AA was automatically enabled
locutus12 said:it has to be a problem with DooM 3, maybe it doesnt like the X1800 range or something stupid like that![]()
Garp said:Wasn't the X1800 released after Doom3 came out? In which case why would you expect it to know precisely what it is?
NotJimNot said:I saw the first question as rhetorical and the second in reply to the statement about Doom 3 not liking your card i.e. it hasn't been tested.
You have to expect sometimes that your postings may have multiple interpretations.
Or maybe I'm just a troll too.
Good luck with getting your card working.
m3csl2004 said:i was gonna post a huge pack of cigarettes but thought it to be a bad move - keep up the good work mate![]()
what drivers have you tried?
OV3RCLOCK3R said:http://www.tweakguides.com/Doom3_1.html
follow that guide and i think it's got something about AA that you can enable through modifying the .ini file![]()
will give it a go in the morning
thanks,
