Driver cleaner ?
15 Mar 2004
Oxford
hi guys,
i see something mentioned in another thread about a tool that make sure there is nothing lurking about in your system drivers that shouldn't be there ?
i don't want to re-install any of my system drivers just check to make sure theyr'e fine any program that does this at all ?
Thanks
try this m8
http://www.drivercleaner.net/
it's free and seems to work quite well.
If you have devices on your mobo that u don't use (paralell ports, serial ports, front USB headers etc..) then disable them in the BIOS it will make your computer start up much faster. If your looking to increase performance by removing device drivers try this it's more effective.
