driver help?
18 Feb 2007
London
hi
i have the following components on the way i would like to burn a cd with all the latest drivers for vista 64bit before i make my pc as im not sure i want to use the drivers they supply because there proberly old , can anyone tell me which of the devices below need drivers
intel core due e6300
bfg 8800gts320mb
gigabyte ds4 (unsure of the revision number until i get) what do i need just the latest bios???
seagate baracuda 250gig 7200.10
thanks for the help
thanks
should i wait to see what revision number my mobo is or does it not matter?
also in the mobo drivers bit theres lots of drivers for the chipset how can i tell which one is correct for that board?
thanks for the help :)
yeah i must check that!
so what ever revision ive got ,say the latest i would download the drivers for that revision?
also under the drivers bit which chipset driver do i need as some say gigabyte and some say intel???
cheers
