take the three items in your pic, and dump them into a new folder on your desktop will be fine.
click the windows "start" button in the task bar, right click the "my computer" choose properties.
you should then see a new window, with the general pc hardware info/ performance score.
there should be Device manager on the right top side, click it.
it will now list every item in the pc, look for network adaptors.
double click this, it should also maybe have a yellow warning triangle next to it.
pick update the driver, you get two options, auto or manual, pick manual, and it will ask you for a destination it should look at, select your new folder with the three bits in.
hopefully it will work.
