Driver requirement identifier?
Man of Honour
17 Oct 2002
I'm back baby!
Hopefully a quick and easy one. Our lass has inherited a tower that's surprisingly high spec (for a free machine) but it has a wireless network card in it that doesn't have any accompanying documentation or identifying information on it.
Is there anything I can install that will be able to find out? Standard generic Windows drivers don't appear to want anything to do with it :/
Any other ideas would be appreciated.
Ta
Open up the device manager (start > run > devmgmt.msc), find the wireless card (will probably have a yellow exclamation mark next to it). Double click it and go to the details tab, then change the property to 'Hardware Ids'.
Copy/paste the lines into Google/here and you should hopefully find what it is.
Spot on, cheers :D
OK, detail from the Hardware IDs window:
PCI\VEN_1814&DEV_0301&SUBSYS_700E1799&REV_00
PCI\VEN_1814&DEV_0301&CC_028000
From Unknown Device Identifier:
Chip: Ralink Technology RT2561/RT61 802.11g PCI
Vendor is blank
Ta, I've got it connected now but it's dropping packets left, right and centre (dropping more packets than are being received by some margin). Weirdly, although it's picking up an IP it still reports that it isn't connected.
[edit]That's with RT256x version 1.2.8.0 installed (running XP)
