- 8 Jul 2003
Hi, a couple of weeks ago I had a bit of a problem with some spy/adware that was causing my computer to run really slow and choking my internet connection, so I decided to format the HD and reinstall XP SP2. Everything seemed to go on fine, got all the latest drivers etc of the internet and got them installed; then maybe 2 days after I reinstalled my pc started crashing.
Sometimes it seems to just freeze up and I can’t move the mouse or use the keyboard, the only thing I can do is restart the computer manually. Other times it just shuts itself down and displays a blue screen error saying ‘DRIVER_IRQL_NOT_LESS_OR_EQUAL’ then when you restart it windows says it shut down to prevent damage to the computer. Its done this about 6 times in 2 weeks mainly when I’ve been opening emule or catalyst control panel; but when its not been crashing games such as world of warcraft have been running really slow and sluggish.
I googled the error I got and it says its either something to do with damaged hardware or software conflicts or something, but it doesn’t really narrow it down past that. I’m 90% sure it can’t be faulty hardware because it was running fine (except for the spy/adware) before the reinstall. I’ve got a feeling it might be something to do with the graphics card because every now and again when I open a page it’ll show a picture but half of it will be distorted with purple/green lines across half of it or something. But I’ve no idea how to check or fix this.
Has anyone had this problem before or something similar? I’m really stuck on this one guys, was reading the result from that google search and it was like another language; any help you can give would be greatly appreciated.
Here’s my spec (all drivers are the latest ones as of 2 weeks ago)
AMD 64 ATHLON X2 3800+
ASUS A8N Mobo
ASUS X800 ATI Radeon
1GB Corsair ram
I think that’s all correct, but I’m at work atm so I can’t really check
ASUS A8N Mobo
1GB Corsair ram
