- 14 Oct 2007
- newcastle
Have they changed the "grading" in the last few months, I'm confused.. When I did my test last October or whatever it was, if you had 1 major you would fail. THis was for not driving safely or things like that (not over taking a bus as well, or not attempting to...if the bus was there for a while you are creating traffic so this was one)
But then otherwise you could have like 13? Minors, so a minor for not doing a side mirror check, things like that.
There are three category's
The correct terminology is driving fault = minor ,serious/dangerous driving fault = major
And your allowed 15 driving faults before you automatically fail
