Drop-down menu problem in Safari iOS
Man of Honour
Man of Honour
3 May 2004
SILENCE!
Got a problem with drop-down menus in Safari on iOS 8.1.1. I'm not actually sure what that thing is called - specifically on this forum, you have the dropdown menu at the bottom of the page that you can use to quickly navigate between the sub-forums. On iOS it pops up as a sort of barrel roller that you can scroll through the sub forums and tap the one you want to go to - that thing. If I tap on this it quickly flashes up the barrel roller but there are already two options ticked in the list and I can't seem to clear them. So I can't navigate between the forums using it. Any idea what has happened? I've tried clearing the history from both Safari and iOS Settings and restarting the phone. Neither has had any effect.
I've never used that before but I just tried it on my iBendy and it does the same.
I never knew that existed but I was unable to un-select the existing options and then select the sub form I wanted and it worked fine.
I'm on a 5s with the latest iOS.
EDIT: Hmm now it is doing it on my phone as well. Very strange as it did work when I tried it earlier!
It's done it since 8.0, but only on iPhone. Both my 4s and my 6 does it, but my iPad is fine. Which would suggest its specific to the phone build of Safari
