Title should be Drop in FPS
Any passing mods change it please?
I'm sure my FPS has dropped in COD4, sometimes if there is smoke especially its noticeably slower, some times its close to 200, it always used to stick around this.
Is there anything I can run that would give a quick check that the card is running as it should be?
Spec is in my sig, single GTX 280
Gaming at 1920 x 1200
GPU-Z reports idle temps, 5 mins ago I played COD4 for about an hour.
GPU Temp 63
PCB 56
Seems hot?
Fur mark run at 1280x 1024
[ SCORE: 3652 o3Marks ] - Time: 60000 ms
Max GPU Temp: 81°C - Max Current: 82.3A
FPS: min=48 max=79 avg=61
And a full blast run
[ SCORE: 778 o3Marks ] - Time: 60000 ms
Max GPU Temp: 85°C - Max Current: 90.7A
Resolution: 1920x1200 (FS) - MSAA: 16X
FPS: min=12 max=18 avg=13
Is this normal?
I was thinking about adding a second GTX but won't if this one has problems.
Thanks
GPU Temp 63
PCB 56
Seems hot?
Is this normal?
Thanks
