Hi All,
I have a DDL which seems to be databinding twice and I can't seem to find out the reason why, the offending code is this...
DropDownList soft = (DropDownList)e.Row.FindControl("DropDownListSoft");
DataSet DropInfo = SQLQueries.AvailSoftware();
soft.AppendDataBoundItems = true;
soft.Items.Insert(0, new ListItem("Select to add software"));
soft.DataSource = DropInfo;
soft.DataTextField = "SoftwareName";
soft.DataValueField = "ID";
soft.DataBind();
When I remove the command AppendDataBoundItems it works fine but with it in it databinds it twice
The rest of the code is...
public partial class CompSoft : System.Web.UI.Page
protected void Page_Load(object sender, EventArgs e)
int PCID = Convert.ToInt32(Request.QueryString["pcid"]);
if (!Page.IsPostBack)
DataSet ds = SQLQueries.SoftwareUsedBindData(PCID);
if (ds.Tables[0].Rows.Count == 0)
ds.Tables[0].Rows.Add(ds.Tables[0].NewRow());
SoftList.DataSource = ds;
SoftList.DataBind();
else
protected void SoftList_RowCommand(object sender, GridViewCommandEventArgs e)
if (e.CommandName.ToString() == "expand")
GridViewRow row = (GridViewRow)((Control)e.CommandSource).Parent.Parent;
string value = Convert.ToString(SoftList.DataKeys[row.DataItemIndex].Value);
//string value = SoftList.Rows[int.Parse(e.CommandArgument.ToString())].Cells[0].Text;
string sScript = "<script language=javascript>window.showModalDialog('softdetails.aspx?pcid=" + value + "','_blank','dialogWidth:290px;dialogHeight:290px;');</script>";
Page.RegisterStartupScript("javascript", sScript);
else if (e.CommandName.ToString() == "add")
DropDownList Software = (DropDownList)SoftList.FooterRow.FindControl("DropDownListSoft");
string SoftwareName = string.Empty;
if (Software.SelectedItem != null)
SoftwareName = Software.SelectedItem.Value;
int id = Convert.ToInt32(SoftwareName);
SQLQueries.SoftwareAddToComp(PCID, id);
SoftList.DataSource = SQLQueries.SoftwareUsedBindData(PCID);
//SQLQueries.GetSoftID(SoftwareName);
else if (e.CommandName.ToString() == "remove")
int id = Convert.ToInt32(SoftList.DataKeys[row.DataItemIndex].Value);
SQLQueries.SoftwareRemoveFromComp(id);
int PC_ID = Convert.ToInt32(Request.QueryString["pcid"]);
else
protected void SoftList_OnRowCreated(object sender, GridViewRowEventArgs e)
if (e.Row.RowType == DataControlRowType.DataRow)
Button expand = e.Row.FindControl("expand") as Button;
expand.CommandArgument = e.Row.RowIndex.ToString();
else if (e.Row.RowType == DataControlRowType.Footer)
soft.DataBind();
//Response.Write("["++"]");
protected void DropDownListSoft_SelectedIndexChanged(object sender, EventArgs e)
DropDownList DDL_Soft = (DropDownList)SoftList.FooterRow.FindControl("DropDownListSoft");
Label MediaNo = (Label)SoftList.FooterRow.FindControl("MedNo");
Label Maker2 = (Label)SoftList.FooterRow.FindControl("Maker");
Label Version = (Label)SoftList.FooterRow.FindControl("Version");
int ID = Convert.ToInt32(DDL_Soft.SelectedItem.Value);
DataSet PopSoft = SQLQueries.PopulateSoft(ID);
if (null != PopSoft && 0 < PopSoft.Tables[0].Rows.Count)
DataRow Soft = PopSoft.Tables[0].Rows[0];
MediaNo.Text = Soft["MediaNo"].ToString();
Maker2.Text = Soft["Manufacturer"].ToString();
Version.Text = Soft["Verson"].ToString();
I really appriciate any help I can get as I have been working on this problem for ages
Stelly
soft.DataBind();
The rest of the code is...public partial class CompSoft : System.Web.UI.Page
else
else
soft.DataBind();
Stelly
