DropDownList in Footer
Don
5 Oct 2005
Liverpool
Hey All,
I have this code which I'm trying to get to populate the dropdownlist in the footer of my grid view
Code:
 protected void SoftList_RowCreated(Object sender, GridViewRowEventArgs e)
        if (e.Row.RowType == DataControlRowType.DataRow)
            ImageButton expand = e.Row.FindControl("expand") as ImageButton;
            expand.CommandArgument = e.Row.RowIndex.ToString();
        else if (e.Row.RowType == DataControlRowType.Footer)
            DataSet DropInfo = SQLQueries.AvailSoftware();
            DropDownList soft = (DropDownList)e.Row.FindControl("DropDownListSoft");
            soft.DataSource = DropInfo;
            soft.DataTextField = "SoftwareName";
            soft.DataValueField = "SoftwareName";
            soft.DataBind();
the sql statement is
Code:
    public static DataSet AvailSoftware()
        string connectionString = ConfigurationSettings.AppSettings["ConnectionString"];
        System.Data.SqlClient.SqlConnection sqlconnection = new System.Data.SqlClient.SqlConnection(connectionString);
        string queryString = "SELECT * FROM Software WHERE LicenceAvail = 3";
        System.Data.SqlClient.SqlDataAdapter ad = new System.Data.SqlClient.SqlDataAdapter(queryString, connectionString);
        DataSet ds = new DataSet();
        ad.Fill(ds, "software");
        return ds;
its not populating the dropdownlist in the code, which is:
Code:
                    <FooterTemplate>
                        <asp:DropDownList ID="DropDownListSoft" runat="server" DataTextField="SoftwareName">
                        </asp:DropDownList>
                    </FooterTemplate>
Help would be VERY appriciated with this...
Stelly
