Dropped XPS 13 - Torx T5 mounting post broke
26 Oct 2013
Leicester
Hi all
Crap day for me. Dropped my XPS 13 9350 whilst it was balancing on something onto a carpet floor. The lid was open and it was on.
The power button does not rest in the correct place anymore and the laptop switches on/off when I open close the lid as the power button gets pushed
It appears one of the Torx T5 mounting posts has broken off
This post is on the opposite side to the power button
Does anyone have any good ideas on next steps? Shoudl I take this to a shop to be repaired?
I understand this post is part of the palmrest
Thanks
If it has left a flat surface you could maybe super glue some nuts together and make a new post that way.
I did something similar when i broke a mounting post for a foot on a turntable and it worked.
I had this same thing happen to my 9550.
I glued it back on, you can replace the carbon shell pretty easily though, about £30 iirc. I replace the aluminium bottom because of that drop as it warped that slightly too.
OK, how did you glue it? Did it stay in place pretty well? Superglue?
Hmm OK, I guess I would not be able to attach this to the laptop though and the nuts would be just loose
No, you build a new post with the nuts and then glue in place of the snapped post.
The increased area of the nut should make it stronger than trying to glue the original post back into place.
Hello all
OK, thanks. If I can't get a reasonably priced palmrest I will consider this...however my ultimate aim is to get a new palm rest fitted. I was quoted £35 to fit by local laptop repairer
Also...
I was informed by an ebay seller that the PCCX7 (9360 palm rest) is also compatible with the 9350 (DJ64X palm rest). This seems to be the case with some of the other ebay sellers listing both PCCX7 and DJ64X as compatible e.g. -https://www.ebay.co.uk/itm/Dell-XPS...569976&hash=item2adf6c6b97:g:WPEAAOSwp5leJeHY
Is anyone able to clarify further?
Hi chaps
Me with more bad news
So I sourced a genuine DJ64X and had it fitted at local laptop repair shop
All fitted fine, however the trackpad is now basically unusable. It does not 'click' correctly like it did before, and the left and right click buttons don't work. The movement of the mouse works fine, as well as the "tap to click" but the click is wrong.
Is this something that could be caused by it being fitted incorrectly or is it likely the trackpad is bust?
Thanks
If you gave them a working trackpad and the correct palmrest for the machine i'd be putting it on them, either they have fitted it incorrectly or have damaged it while swapping over.
OK so took it into my own hands...
Y7KvdTuifC5GOGQj_15k3ayDhtHomcvrUkLnXpTO3ugmM0lfeaN0a3jBinrQvi9gLA1ZMdy32-NwnUStGeKs944q32sItcyNKdcT6VaXLMFeOrRLV__OwiqyM15Qugz9yvRsHFAcxhxsx-HAQxtXJ2X98130afEqSfER3Grg9vCR-eP3kFkqxmvHvsGBz6x6gRSpYQKvjk919PvLoLBYCVqVNAj1c-HerEWNJwKpUgrpDLSKs5PWzjty1uGxUNjkMbIqm5GvxPpQCH4nfdVJu7CRh2IaD3iTsS3kZ94LIX9vuB9jHZ1O90r-ABTmJbh-giWdsoXXRMenr6IjOGurcw4wjVGrqdVhfTNsRvUr7ovCiN5l6EGOhCO40uR6FsiuIpx9C0p8aKCEFWXFt1o2Yf1Xzwk-6VP3A6p94G_iLBsCZ4FA-6iJMyJt_zyFhE7Yn6xTfkO46LApa7RyIM8l8Uj-KmaxQueUEFYf5JEv-uvIG1DXfq3KYKxOZSn2wtXoVUT8P3f-xmmlOaTtgFIOYuIoU5v_k2B1S_crNEAHuyGP0cc5jYgwSTnfCNnN6pOm0s32YCrlxHAmvvF_wZD3Q-wiDqxNYp8gDSLbSYHi_hZgserKKfHkym3yaJJaZxx6bQZkkRdDbcMcv6nbew4_avfO8ncvQwr-awqpQ7HY-3jdsmy_pjHXHw-4Rpbj0A=w973-h1297-no
Thats the old palmrest. You see that greyish coating? That is not there on the new one
2Y8Zbac_bEZixw2y40kS0JcNFm9Wew4fANgkEBPtdpw9IkKbuyIizqpNLAkWibmfhScZy8ykRzytZiIJ1zH1W3oj3m5p-2t5r0DgwuApX48u1CIQ8sTshkQNsBAOPuFodaGe_9FNf5qI2y7RiBxAJoVpskcz45XBoeiJM2OI4cVQjaJAOp9IUFoRoFiaaI84sL6mu6Mgozvc3hQhdkx6hqmh28XjKU6w6KbE4kt4lQaoyhk7Tl-JwDZULVW2Z4hGKxTwOexBCSbvcm-bQ7yJgYQn1IxLTtE1XMI_UfUPvw5US-rIp9wlEgxReQYxSK9aCnpG2nufqkaP8DsBSDJMxyog7S0Bbtds4pYsifKPPXVdIclJlALAATpyhmz0J_yC73Bzev3ygK93wrTYc7w5nR4eIrw-HGt_jSVNReeTLWUi6ehssM-QiyiFA1x73Pe2Uy8HkcpiuW9nESzeeKI4-CZWoPbTBni_rr7jyJVYWh7zfm2Rqc-Zfzc2f0MXh0a1r264QrpWxUMbcvroeCNyxnmul1k6ENOWFlt_oy9PPgo52lRZXDvK4_nFl2lR4o06L7wDX3tVvZpAcWmvlK0I7ruQlp-iaIyh2Rp7_NXOwvBLDKbmy93_bF0CRNKYef1xEWjeud3HhYPYQrI_GOWqkNqV4LTnin-GXnHSNdO3bAJfCi-6LyjSiyfy6QBWFg=w1730-h1297-no
It seems that layer is a little thinner and thus it doesn't click properly. Am I right in assuming this is some kind of grounding material to help the touchpad detect what side is being clicked?
Just by looking at it the only thing i can think is that maybe the grey material is meant to push the trackpad up a bit.
Does the trackpad sink into the palmrest while pressing it ? Does it feel spongy at all ? Does it actually click and do nothing or is there no click at all ?
So I have fixed it now
You are pretty much right there it seems, what I have done is used a small amount of masking tape as a "washer" to increase the thickness of the palmrest.
Now it works great :)
What I hadn't realised is that the trackpad has just a single metal button on the bottom, and it detects left/right click from where your finger is on the trackpad
