Hi all,
I've finally got what I wanted for the last 10-15 years - a detatched house with a single width garage built in. Next door is around 3 ft away on a completely seperate concrete slab. The house is rented however so what i'm designing fits around certain things in the garage that can't be moved (gas main), but also i'll build certain parts with screws so it can be disassembled.
My hobby/ main interest is drumming. I've always wanted a drum room to practice in with a proper acoustic kit rather than electric. So my project over the next month or so is to build a room within the garage. The garage itself is a typical breeze block construction with a single layer of brick on the outside.
I am limited with dimensions so it isn't as big as i'd like, but it's just enough. Noise wise it doesn't have to be silent (that's impossible) as my next door neighbour works during the day and said she's fine with a little noise early evening. There is nobody else nearby to hear.
I've started designing things in sketchup after looking through dozens of forums. The problem is, most of it is American - everyone has a slightly different opinion and use case and people just talk in inches. I'm a metric guy and buying everything, obviously in the UK.
Although I've done tons of DIY over the year and construction I've never built a wooden based frame, insulated with a floating floor. That's the goal.
Here's what i've done so far in sketchup:
No noggins put in yet, no insulation shown yet.
Questions I hope someone could help me out with:
1/ Frames should be built with 4x2's. - 38x89mm CL16 CLS is right? https://www.lakesidetimber.co.uk/38x89--c16-cls-24m-x284x2x29-6852-p.asp Anyone found a cheaper source?
2/ Stud distance - I think 24" centers are ok. In the UK insulation seems to be sold in 60cm widths, so I should make the distance between the studs 60cm and not centers?
3/ Should the celing studs be closer than 60 or you think it's ok?
4/ I'm planning on using 18mm OSB on the floor, and perhaps 11 on the walls / celing. If it's not enough then I'd put on a second layer, different orientation. Internally obviously plasterboard is most people's choice but again I'm leaning towards OSB as it is easier to screw / remove.
5/ Insulation - rockwall as dense as possible all round. Floor - I'm planning to buy some foam spacers that the studs will sit on, existing concrete floor under that which is also already covered by carpet.
6/ Door - planning on FD30, but I'm height limited so not sure a standard sized height will work (1981mm). Looks like you can buy custom dimensioned doors so will have to look into that but so far they are 3 times the price of a standard one you can get at wickes etc.
7/ Electricity / lighting is sorted. Might buy a wall mounted aircon unit for ventilation.
Any thoughts comments welcome, really appreciate any help!
Happy to post some updates as I go if anyone is interested.
