Don
- 20 Oct 2002
- In a house
I went out to clean my car today, after drinking a few too many of these..
I noticed that the headlight was slightly wobbly, and popped the bonnet, and saw that two of the headlight mounts were broken, and the only one left holding it in place had a HUGE crack in it.
So i ended up trying to remove it. Unfortunatly, Honda decided that in order to remove the headlight on a motegi kitted front end, you have to remove most of it!
However, having started i couldnt stop, and it was cold!!
I ended up with this, whilst i re-constructed the old mounts on the headlight unit.
Headlight cracks
You can see the cracks are all filled and lined with superglue, and the mounting bracket is strapped in tight to get it back to where it should be!
End result, its all back together, and the headlight fits properly and works as it should, and nothing is moving about
Headlight cracks
