Unfortunately, there aren't any good DS homebrew browsers, most likely due to the fact that there's limited memory. So, I'l looking at getting the official browser instead. However, the main thing is which to buy. I know there's two, one for the chunky DSs and one for the lites, but on the jersey site, it says they are incompatable. Obviously, I know that the lite pack couldn't fit in the chunky DS, but surely the reverse isn't true? I've got an old and new DS, and would ideally like one that could be used in both DSs, not minding that it sticks out a bit.
The second question is one of functionallity. I'd mainly be using the browser for one site which uses frames (the homebrew browser I have found doesn't support them). Are they a problem?
The site itself is basically a chat room, using one frame to display all the text, one for the user list and one for entering text. Does something like that work on the DS browser?
Finally, what's the keyboard like? The DS AIM client I have is great, but the MSN one is rubbish.
Thanks!
Thanks!
