DS lite and wireless router?
Apparantly it doesnt work if you have WPA enabled, it only supports up to WEP. Also somebody said in another thread that if you lower the router speed to 1-2mbps, it can also solve problems.
Il have my DS later so il be trying this out this evening.
You shouldn't need to adjust the router speed, it should automatically negotiate the speed, assuming the router can work with the B standard.
Like I said in the thread that other guy was referring to a lot of routers require the speed to be manually set before the DS will connect to it.
sorry for the thread jacking but can anyone recommend a good wireless access point for my wired linksys router, which would work for both DS and XB360?
