- 27 Jul 2005
- The Orion Spur
Same, although a lot of people have reported problems.EezerGoode said:I done mucho messing aboiut trying to get various dongles to work as AP's. No sucess.
Bought a nintendo wi-fi adapter, was online within 2 minutes.
JaFFa said:Just start a wifi game and select wifi configure. Search for your SSID and then type in the wep/wpa key. simple as, really.
, think I'll just order an official Nintendo one, thanks anyway guysAt least for but I'm pretty sure it's up to 7. Will have to google for a definite answer.gazzaa said:how many ds's can run off one Wireless adapter
Cronox said:I was under the impression that the DS couldn't connect to an AP using WEP?
JaFFa said:o right, iver never actually tried because I rem my psp couldnt use wpa so i moved over to wep. I know now the later firmwares of psp do work though with wpa.
I use it a lot. Mario kart, metroid and Tetris are fansatic. Tony Hwaks isn't bad as wellCronox said:I did the same thing originally but never ended up using the DS online much so switched back to WPA
