DS Lite Wireless connection problems
18 Oct 2002
Cambridge
I have a Zyxel Prestige 660HW which matches the ZyXEL Telefonica Prestige 660HW 61 on the compatible routers list but just can't get it connected. I've tried it initially with my current settings but have dropped it down to un-encrypted, no mac filtering, dhcp visible SSID but it still won't connect. It did see the network though. Always get Error Code: 51300. Any ideas?
From Nintendo's WIFI service help pages...
http://www.nintendowifi.co.uk/customersupport/troubleshoot.do?error=51300&x=12&y=9
Error Code: 51300-51302
The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
What to do:
Verify the Access Point's WEP Key and try again.
If you need assistance, click here and select your router manufacturer and model number. If available, our router pages can provide specific steps and information that may help you with your router's WEP Key.
