It turns on for a split second, the bottom screen flashes then it turns itself off.
I've tried with the charger plugged in, so it is not the battery. I took it apart to see if anything was lose, and I noticed that the ribbon cable connecting the upper LCD has a small rip in it; could this be causing the problem?
