DS WiFi Probs
29 Dec 2005
Northants
Hi guys I've got a problem connecting my DS lite to my net gear dg834pn I'm trying to connect it using the game pokemon diamond but it don't seem to be picking up any wireless routers up
Help please :D
WEP the ds won't even find the router at all I've got it to broadcast the SSID, I've only just got the pokemon game, I'm trying to connect in pokecenter trying to get my Friends code if that makes any difference?
When I shake the DS lite something sounds like its moving I brought it second hand dunno if that has anything to do with it.
Try setting up the wireless from the menu you get on the DS when you just switch it on, just to rule out anything game related.
The shaking doesn't sound too good, though it's obviously hard to say if it's related.
I've found the settings and now the router all I've gotta do is test it out when I'm ready but I can pretty sure say this is sorted not sure what the thing is inside :D Thanks guys
Edit: Works now got my own friend code w00t :D Thanks!
