Righty, my 680i is being RMA'd, so i got meself a stopgap DS3.
Installed the thing alright, upped the bios to f11.
Now i have an e6400 that was happily sat at 3.5ghz, and boots to windows at 4ghz (not at all stable though)
Now i firstly started to look desgutedly at the bios when i found i couldnt run the mem unlinkd, so i loosened the timings to 5-5-5-15 (ocz platinum pc6400 c4 2gig kit) and upped the voltage to +0.3v on the ram and set the devider to x2, set the cpu vcore to 1.575 (i know its high, but its a cold chip and this is what was required for 3.5ghz in the 680i)
f10, y, and the thing turns off
and keeps restarting, this worried me for a bit untill it happened a few times after changing something in the bios, so i assume it's the way the bios gets saved to and also the way it recovers itself (first question, is this so?)
Any ways, after some fiddleing, i can only get it to boot (and is perfectly stable by the way) at 400mhz can adjust all the voltages quite high upwards and this doen not cause any boot issues, only when i up the FSB past 400mhz, so im assuming this means 1 of 3 things, cpu cant handle it (which it can...) ram cant handle it (i've had it at 1200mhz, so im assming this is not the case..) or the motherboard wont go past 400fsb...
Would this be a safe deduction? Anything else you guys think i should try?
Cheers!
and keeps restarting, this worried me for a bit untill it happened a few times after changing something in the bios, so i assume it's the way the bios gets saved to and also the way it recovers itself (first question, is this so?)Any ways, after some fiddleing, i can only get it to boot (and is perfectly stable by the way) at 400mhz can adjust all the voltages quite high upwards and this doen not cause any boot issues, only when i up the FSB past 400mhz, so im assuming this means 1 of 3 things, cpu cant handle it (which it can...) ram cant handle it (i've had it at 1200mhz, so im assming this is not the case..) or the motherboard wont go past 400fsb...
Cheers!
